trailblazer 302 blown engine
  • trailblazer 302 blown engine
    I am so upset right now. My 302's motor blew up, the con rod of course just like all the other ones. I knew about the issue, I changed the oil with full synthetic every 100 hours a lot of the times it was 90 hours. Changed plugs, both fuel filters, and air filter every single oil change, I went way above what was required in fear of it not lasting. At 1500 hrs it started burning a bit more oil and then got worse. Almost 1/2 litre every 10hrs run time. Took it to a kohler dealer and they said it was normal. 3400 hours it blows up, owned it for 6 years. I paid 4500 canadian and now a new one is $7500!!! Looking for recommendations on what I should do. Buy a new motor and have it installed? If I do that with the generator having 3400 hours on it how much longer is that going to last as an estimate? Couldn't come at a worse time.
    1/2L every 10hrs run time normal?! I'd say that Kohler dealer/tech threw a rod too.
    Are you mechanically inclined? Could likely rebuild the original for less than having a complete new engine installed. That's if itsimply broke a rod and didn't damage the block and other components. I'd run the numbers including having the block bored if necessary.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
      I was thinking the same thing...Bob
        It had something to do with the harmonic balance with your TB302 and the Kohler engine. Welding at a certain temp all the time created flex in the crank shaft and would break the crank at the rod. I've never seen a broken rod buts possible. Second, I've seen Kohlers with 5000 hrs still not using a drop of oil. Your Kohler dealer was wrong. I wouldn't fix it unless you are sure it's just a rod. I suspect it's the crank too.
          Is this issue on the trailblazers or did it effect all the Kohler engine drives? Is the issue fixed on newer models?
            It was only on certain years of the TB and not on the Bobcats. The issue is non existent on newer machines.
              All the small gas engines are throw away 3k hrs machines, We have had 2 that around 2500 to 3k they started to need motor work. If you use it everyday I would look for a low speed diesel.
