WC 1 and spoolmatic 1 on bobcat.
  • WC 1 and spoolmatic 1 on bobcat.
    I'm looking at an add for a WC1 weld control box and a spoolmatic 1 spool gun. It appears to have a lot of connections and cables/plugs. I'm not 100% sure what I need to use this set up with my bobcat 250?
    If everything is there, will the set up work well with the bobcat?
    Lincoln Idealarc 250
    Miller Bobcat 250
    Thermal Arc Hefty 2 feeder
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    I think the WC-115A with the contactor installed and the 30-A is your recommended option for that machine. After that I got nothing.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
      This is the adapter my Trailblazer 302D needed to run my 30A spool gun. Its the WC-24, if youre bobcat is newer this may be what you need also, it ran $175 used on ebay, bout $400 new if i recall. Plug facing in photo is what hooks to the machine itself, good luck
      Miller 210 w/2 3035s (pc board died, need help!)
      Miller 252 w/ 30A
      Miller 350P w/ XR Edge
      Miller Diversion 180
      Miller Syncrowave 250DX w/ wireless pedal, cooler
      Miller Trail blazer 302D w/ 30A, X-treme 8VS
      Miller XR box
      Miller WC115A box
      All BLUE Baby, all BLUE! Well except that X-treme box' lol its BLACK!
      hypertherm powermax 65
        I'm guessing the Bobcat doesn't have an output contactor since both controls recommended for it specify a contactor kit. I don't know if there is a way to adapt the contactor kit to the WC1. so I would assume that you wouldn't be able to turn the weld current off without a contactor??
        https://www.millerwelds.com/support/...n-hookup-chart
          The bobcat is new. 2017 model.
          My manual shows a drawing for spoolgun operation and it shows a WC with an optional contactor. It says the contactor is recommended.
          Miller Bobcat 250
          Torchmate CNC table
            The
            bobcat does not have a remote hookup.
            I could see where this would be the way to go with a trailblazer.
            Miller Bobcat 250
            Torchmate CNC table
              My research is telling me that the wc1 with spoolmatic 1 will work. However the wire will constantly be hot due to no contactor. This is the most inexpensive way to do it but not the ideal way.
              Miller Bobcat 250
              Torchmate CNC table
                Yes, the WC-1 and Spoolmatic 1 will work on your Bobcat. I know because that's the setup I have for my '96.
                However, it does make it a bit tricky to use without a contactor as the arc will follow the wire back to the contact tip after you release the gun trigger. This will almost always result in melting the wire to the tip unless you pull the gun away quickly as you release the trigger.
                I don't have that issue as I've modified my Bobcat to include a contactor and 14-pin remote receptacle which I don't recommend unless you have the knowledge/ability to do so as it's quite involved.
                http://weldingweb.com/showthread.php...ion&highlight=
                Syncrowave 180 SD
                *HF-251D-1
                *WC-1S & Spoolmatic 1
                PakMaster 100XL
                Marquette "Star Jet" 21-110
                  Yes, the WC-1 & Spoolmatic 1 will work on your Bobcat. I know as I have that setup for my '96 Bobcat.
                  However, it'll be a bit tricky to use as the arc will follow the filler wire back to the contact tip unless you pull the gun away as soon as you release the gun trigger without a contactor to break the arc.
                  I don't have this issue as I modified my Bobcat to include a contactor and 14-pin receptacle which I don't recommend unless you have the knowledge and skill to do so as it's quite involved.
                  Syncrowave 180 SD
                  *HF-251D-1
                  PakMaster 100XL
                    Yes the WC-1 and Spoolmatic-1 will work on your Bobcat same as it does on my '96. You'll need to pull the gun away at the same time you release the trigger to prevent the arc from following the filler wire back to the contact tip which usually results in welding the wire to the tip. A WC-1 with optional contactor (WC-1C) would solve this.
                    Syncrowave 180 SD
                    *HF-251D-1
                    PakMaster 100XL
                      Syncrowave 180 SD
                      *HF-251D-1
                      PakMaster 100XL
                        Site won't let me attach the link but if you go to the weldingweb forum and search Bobcat 225G Plus 14-pin Receptacle Conversion you'll be able to see how I added a contactor and 14-pin remote receptacle to my '96 Bobcat.
                        Syncrowave 180 SD
                        *HF-251D-1
                        PakMaster 100XL
                          Cool, much thanks Duane.
                          Miller Bobcat 250
                          Torchmate CNC table
