syncrowave 250 transducer HD1
  • syncrowave 250 transducer HD1
    Anyone know of a shop that rebuilds part number 156313 miller transducers?
    Hello Ron, just curious. What is the issue with your HD1 ? I was checking mine and I get 1725 ohms should be 1600.
      My welder just quit working. I took it to a miller repair shop. Called and told me they could not fix it because obsolete part. I found a replacement part number 124684 and it is working ok. But I would like to get the 156313 up and running if possible.
        Good luck, I hope it works out for you.
          My HD1 also tested at1763 ohms.
            Hmmm! I wish I knew what the tolerance was. My weder works fine unless I use remote amp control. P.s. I just found the tech manual says + or - 10% . Yours is just barely over that, easily within the tolerance of most dvom's
