Also the polarity - if your machine's set up for DCEP and you have your DC ground clamp set for DCEN, it won't work..Steve
Does a MIG machine for alu have DC/AC switch?
Did not know much about 'AC & DC ground clamps'. Wonder if this means the same as this ad tells below, it seems there are some more complicated AC/DC MIG machines like 'YD-350AZ4'; https://industrial.panasonic.com/cdb...AAB3000CJ8.pdf
This ad paper above says it provides alu welding of TIG-grade with this MIG machine, and its price is way high though.
A short review here too;
" Figure 1 shows two such welding current and welding voltage control devices, (a) a remote control for an analogue welding machine and (b) a digital controller (the YD-350AZ4, the most recent digital/DC- pulsed MIG welding machine produced by this company)."
Found a sample here on a local auction site here; Panasonic YD-350AZ4
https://page.auctions.yahoo.co.jp/jp/auction/v534141684Last edited by chy_farm; 01-20-2018, 05:28 PM.Oxy-A (Koike, Sakaguchi)
HITACHI Inverter Pair 300GP(AC/DC TIG)
Originally posted by chy_farm View PostI have a good pro grade TIG welder but it does not allow me to use one of my hands, lol, so beginning to think of buying a MIG machine for aluminum.
You guys are ****S! LOL
So...as a rule, tig and stick machines are constant current. Current=amps. So you set the amperage and go. Any stick machine you can at least DC Tig off of. You do need A/C current for Aluminum. AC current alternates between DC +/- . You need the + to rip off the oxide layer that has a 5000 degree melting point to get to the aluminum with a 1500degree melting point. But need the - side of things for penetration. On super thick blocks of aluminum, you can use DCEN on aluminum when tig welding. Going to be smokey as he'll, but it can be done.
Wire feed machines are CV. Or constant voltage. Set the voltage, as opposed to CC machines where voltage is controlled by arc length. You can mig aluminum from any CV machine. Positive polarity DCEP, meaning what is in your hand is hooked to the positive side, for any solid wire...aluminum,steel,stainless,etc. The ground clamp is negative...and no, there is no ac/dc ground clamp. Self shielded flux core wire needs dcen. Gas shielded flux core wants dcep. Gas wire welding you want +.
No such thing as an AC mig or flux core...unless we're talking input power. So there's no such thing as an ac/dc switch for an aluminum mig as all mig machines can weld aluminum
- Likes 1
