Well, I've had my 200DX for about two weeks now, and been welding for about a week. I had to buy an aircooled torch last week, so I could get up and running, as I can't find the ridiculous QC fittings for the Crafter series torch, and Weldcraft wont sell them to me. So I have a worthless $500 torch as it sits right now. I would say I wouldn't buy any more of their products, but they make pretty much every torch out there. I was down for two weeks trying to find that fitting, had it ordered from three different suppliers, and none of them has come through with the part I need.
So I'm stuck with burning my hands at 150 amps with a #9 torch for now.
The Dynasty, on the other hand, is everything I expected- but working with an aircooled torch sucks. I put a jumbo gas lens setup on it, which helps a little with the heat problems, but WC torches have spoiled me. I'm used to being able to crank up the amperage, and see my arc envelope remain stable. Not getting that with this torch. Also, my supplier only had a valved model, so I have two gas points to mess with, and ended up blowing an entire 120 CF tank of Argon in two hours, due to the sensitive handpiece valve getting bumped after I previously set my gas flow. I think I was around 50 CFH the whole time I was putting my welding table together, only noticed after I was breaking down, the condensation all over the regulator housing.
I'm going to upgrade to the biggest tank I can get this Friday, and I'm thinking I'll have it filled with He/Ar mix. Any ratio suggestions? I am still going to be doing mostly medium thickness Aluminum, with some Stainless and mild Steel- would I be better off sticking to pure Argon?
