Miller capacitor
  • Miller capacitor
    Not having any luck finding capacitor 31-602. Anyone know where one can be found?
    Tried miller4less.com?
    Ebay?
      Did you try calling miller tech support maybe they could get you the values and you could order one from a supplier?
        http://miller4less.com/advanced_sear...=13&search.y=6
        $100 each. The values are there, too, if you want to try to cross reference with something else.
          Mica, .002 mfd, 1000 volts according to Miller4less. Depending on the mechanical mounting, you may be able to find something at Mouser, Allied Electronics, Digikey, or even a place like Marlin P. Jones occasionally has something like that. Also try Fair Radio Sales, (Lima, OH) and Mendelson's (Dayton, OH) --that is a value that might also be used in a large transmitter. Unlike electrolytics, mica caps don't generally fail from age
          (unless they are oil filled and spring a leak) , so I would not be afraid of buying one from surplus.
            If you can figure out how to mount it, you could try this one from Fair Radio--.002 at 20KV. First item on the page. Seems it should work, but I'm not a welder expert. For 10 bucks, it may be worth a try. Just be sure you have someone who understands high voltage circuits help mount and wire it; not a job for a novice. Could be dangerous if done incorrectly.
            https://fairradio.com/capacitors/hig...ge-capacitors/
              Thank to all talked with miller tech found it same cap different #
                Nice !hopefully your melting some metal soon,keep us posted .D
                  Fantastic! Way easier than trying to adapt some other part.
                    What was the new part # i just picked up a 330 with the same cap(2 of them on the hi freq board that are leaking) would like to replace them, the 330 starts an arc still but just would like to replace them as im sure its not long before they cause a problem
                      I was thinking of trying these
                        $3.50 is alot better than $150 from miller
                          But that's the wrong value--it's .00024. The "4" on the end probably isn't a big deal, but it's ten times less capacitance that the .002 that's in there now--I would not go there.
                            Yeah i get the .0004 difference but thats why im here to see if anyone smarter than i can confirm that it will work or that it wont.. currently the hi freq starts the arc just have to be pretty close for it to jump. It was just a quick test when i picked it up. Once i get everything cleaned and re set the gaps ill take pics tomorrow and post them up of the hard resin? That is/was drilping down the board from behind those caps on thr hi freq board
                              Mine have been like that for god only knows how long. Maybe they were replaced at one time, but it wasn’t by me. Sometimes mine has some trouble starting the arc as well. Just hadn’t had the inclination to make that repair or really look into just yet.
