Tap and die set
  • Tap and die set
    I'm in need of a tap and die set. I have been looking at Irwin 117pc set but I'm not willing to pay for drill bits and have them included as part of the total tap and die count, kind of a rip off to me.
    what do you guys have a line on for a good set to cover both SAE and metric? I would like to have a good variety. Is it worth having Titanium coated? Or what metal is good for them, HSS Or something else.
    just had run into needing to retap stainless exhaust tips for a car but found another way out. Would a regular tap set got it done?
    I have a hodge podge of taps and dies. I use what I can buy cheap. Old stock USA made stuff...Bob
      Stainless can be mean, but it depends on how big a hole and how deep to judge the difficulty in having success. A cheap tap and/or wrench and your day has a good chance of going south.
      As far as a set goes...not sure of the quality of Irwin stuff as of late. I know a lot of their stuff is outsourced to China now, but I don't know about the tap/die sets. I get my taps and dies from my local fastner outfit, and I don't mean Fastenal. It's the kind of place that is primarily a fastner shop but they stock abrasives, make hydraulic hoses, all sorts of industrial goodies. They provide me an excellent source for high quality taps and dies when I need them.
        Are you needing a tap and die set, or a thread restorer set?
          Tap and die set.
            I've bought some specialty bits from these guys before. If I was in the market for a full set, I think I would consider these. The drill bits have been good and I like the warranty.
            https://www.ebay.com/itm/182602463032
              For our service tech's I got Westward brand sets from Grainger they aren't the best but they're not bad as the guys need replacements I get the good stuff from a small local tool supplier.
                Do you find Grainger to be typically more expensive (across the board) then other industrial suppliers such as MSC?
                Richard
                  Yes the list price is generally higher for name brands but not to bad with there own brand (Westward). They are also 1 block away so I can get stuff in minutes vs. days.
                    I use the Klutch sets from Northern Tool. About $80 for each set, but they are very complete. In fact, I just checked and they're on sale for $67 ea set (SAE and Metric).
                    Eastwood MIG175 w/spoolgun
                    Eastwood Versacut40 Plasma cutter
                      The Irwin's are made in the USA, use 5/16" - 1/2" coarse & fine to clean up threads. When one gets dull, replace it.
                      The small Irwin's are not made to actually made to make threads on a steel rod, but work all right on aluminum because the dies are too thin
                      To properly align the die to the rod or shaft.
                      The make well aligned threads need a thick die with plenty of non tooth smooth taper to guide the did on the rod.
                      industrial supply like MSC, McMaster-Carr has the thick heavy duty dies.
                      Prefer the dies with hexagon sides rather than round with a set screw dimmable because of slippage.
                      Prefer using dark thread cutting fluid for steel and aluminum thread cutting fluid for aluminum.
                        A tap and die set with drill bits included isn't necessarily a "rip off." Many taps require you to use a specific sized drill hole, and often those aren't standard sizes. They're lettered drills that would fall in-between the standard sizes. That's why some tap sets include them.
                          Irwin is junk, not the quality like they used to be. Look into DRILLHOG. I bought their drills and tap and die sets. Drills so far work great. Have not tried the tap and dies yet. look them up on ebay.
                          2- XMT's 350 cc/cv
                          1- Blue star 185
                          1- BOBCAT 250
                          1- TRAILBLAZER 302
                          1- MILLER DVI
                          2- PASSPORT PLUS
                          1- DYNASTY 200 DX
                          1- DYNASTY 280 DX
                          1- MAXSTAR 150 STL
                          1- HF-251 BOX
                          1- S-74D
                          1- S-75DXA
                          2- 12-RC SUITCASES
                          1- 8-VS SUITCASE
                          2- 30 A SPOOLGUNS
                            That's the link I posted. I like their bits for sure.
                              Thanks guys for the info I really appreciate it. I would like to get a set like the Vermont American master Set when they sold them. I never had a set just a tap here and there. I would like a set in a case I can't stand having a box or drawer full of floating tools plus it makes it easy to see if one has lost it's way back.
                              I think I would like the HSS set unless the carbon or tungsten sets are just as good. Which of the 3 metals would last the longest? Or am I over thinking this. I would be 99% of the time fixing stripped threads on auto repairs and the like so metric would be mostly used but would want SAE also. The biggest would have to tap for an engine cradle which I have one floating tap for that, somewhere.
