MIG for on-site?
211 or 215 would work for 1/4" no problem. I've done 1/2" by way of a a double-V bevel, and multiple passes. The M100 mig gun was smoking, but it did not compromise it. Still works, but I now use an HTP M25 250A mig gun.
I have a 211 autoset............Great machine.......in the shop or take it along........I have a 225 Bobcat on the service truck......so good to go 120 or 240.. and although I like arc welding in the field , sometimes the Mig on long runs works really well...........I've used both gas and flux core...outside in the right conditions.
MM211 is an option --- I have one, luv it. Mine seems to do just fine out in the field in "windy" conditions (flux core).
Depends on what and where you're welding. Don't count out dual shield. I like dual shield. With the 200 and 215 you have the tig and stick option as well.
Multimatic, MM211 and MM215 are all contenders as they're light enough to haul around. They will all be limited by input power if 120v is your only choice on site.
MIG for on-site?
Hi All,
Most of our welding is done in the shop but once and while we have to go out in the field to do some welding for installtions. Looking for a portable MIG unit that could do up to 1/4” Steel. Any suggestions appreciated.Tags: None
