Multimatic 215 question
  • Multimatic 215 question
    Watching a Miller You Tube video on the unit being used in MIG mode I noticed that the wire speed "read out" transitioned to an amperage value while the operator was running a bead. Miller mentions nothing about this in their literature on the unit. So I was wondering if any one knows if there is a hold timer on the amperage value that would allow you to view it after completing a weld.
    You have a link to the Video?
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
      Ed,
      If I 've done this correctly, the video should starting out close to the point were I noticed the wirespeed to amperage change. Of course I had the video on full screen when I noticed the display change.
      Well it looks like the video is going to start from the beginning. If you jump forward to 9:30 in the video it places the video close to the point were you can easily see ( in full screen mode) the machine display while the unit is being used to run a bead.
        Interesting - The MM252 will show actual voltage but there isn't a way to hold that info.
        I imagine the 215 is the same way.
        Ed Conley
        MM252
        MM211
        TA185
        O/A set
        SO 2020 Bender
          If you flip your helmet fast enough you can see the last second or two of the amperage display. No way to record the view that I know of, but call customer service, talk to a product engineer, they can tell you how to get into all the secret menus.
          Ryan
          __________________________________________________
          DYNASTY 350 w/Wireless pedal
          COOLMATE 3.5
          CK WF1
          MILLERMATIC 350P w/Bernard BTB300 w/XR-A Python 25'
          MULTIMATIC 200 w/Spoolmate 100 w/TIG w/Wireless pedal
          SPECTRUM 375 X-Treme
          (2) DIGITAL ELITE helmets
          Weld-Mask goggles/hood
          OPTREL e684 helmet
          SMITH torches
          HARRIS torches
            Ed,
            By "hold timer", I meant that the read out holds the value for a few seconds after a weld is completed. The meters on my Migmaster 250, Fabricator 181i, and Fabricator 211i function this way. I contacted Miller and a weld tech confirmed that the amperage is held for a few seconds after completing a weld.
              ah got ya.
              Ed Conley
              MM252
              MM211
              TA185
              O/A set
              SO 2020 Bender
                Nothing magical or secret menus. Just standard advance menus. See https://youtu.be/erDPAzcq4YA
