Watching a Miller You Tube video on the unit being used in MIG mode I noticed that the wire speed "read out" transitioned to an amperage value while the operator was running a bead. Miller mentions nothing about this in their literature on the unit. So I was wondering if any one knows if there is a hold timer on the amperage value that would allow you to view it after completing a weld.
Multimatic 215 question
You have a link to the Video?
Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Originally posted by Broccoli1 View PostYou have a link to the Video?
If I 've done this correctly, the video should starting out close to the point were I noticed the wirespeed to amperage change. Of course I had the video on full screen when I noticed the display change.
Well it looks like the video is going to start from the beginning.If you jump forward to 9:30 in the video it places the video close to the point were you can easily see ( in full screen mode) the machine display while the unit is being used to run a bead.
Joining dissimilar metals is easy with the versatile, all-in-one Multimatic 215 multiprocess welder. Watch as Josh Welton of Brown Dog Welding MIG welds the...Last edited by Danny; 10-06-2017, 04:23 PM.
Interesting - The MM252 will show actual voltage but there isn't a way to hold that info.
I imagine the 215 is the same way.Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
If you flip your helmet fast enough you can see the last second or two of the amperage display. No way to record the view that I know of, but call customer service, talk to a product engineer, they can tell you how to get into all the secret menus.Ryan
DYNASTY 350 w/Wireless pedal
COOLMATE 3.5
CK WF1
SPECTRUM 375 X-Treme
(2) DIGITAL ELITE helmets
Weld-Mask goggles/hood
OPTREL e684 helmet
SMITH torches
HARRIS torches
Originally posted by Broccoli1 View PostInteresting - The MM252 will show actual voltage but there isn't a way to hold that info.
By "hold timer", I meant that the read out holds the value for a few seconds after a weld is completed. The meters on my Migmaster 250, Fabricator 181i, and Fabricator 211i function this way. I contacted Miller and a weld tech confirmed that the amperage is held for a few seconds after completing a weld.
ah got ya.
Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
Originally posted by xryan View PostIf you flip your helmet fast enough you can see the last second or two of the amperage display. No way to record the view that I know of, but call customer service, talk to a product engineer, they can tell you how to get into all the secret menus.
