Miller 44D output
  • Miller 44D output
    We have a miller trailblazer 40 4D serial number is JE789397 it worked fine the last time we used it. started up no output at all
    When you say "no output at all," please verify you checked all three polarities: DC-. DC+, and AC. Do you have 120V AC at the receptacle?
    You have a model number typo in your post, I'm assuming, as if it was from a speech-to-text program or something. I went off the model number provided in the subject line.
      Yes sorry about that 44D no out put AC DC or 120 ac
        How long ago was "the last time"? Generator rotor may have lost its residual magnetism needed to kick things off.
        I would start with cleaning the three rotor slip rings with some 320grit sandpaper and if it still won't wake up apply 12VDC(+) to the center slip ring brush terminal (lead #5) and 12VDC(-) to brush terminal of lead #6 for a couple seconds with the unit running.
        Syncrowave 180 SD
        *HF-251D-1
        *WC-1S & Spoolmatic 1
        PakMaster 100XL
        Marquette "Star Jet" 21-110
