Foot pedal value for tig
    If it is an L-Tec built machine
    this is the likely pedal ... (call SSC to confirm)
    https://www.ssccontrols.com/product/...ontrol-pedals/
    https://www.ssccontrols.com/wp-conte...t-Controls.pdf
      Thanks guys, probably sell this one and just pay the 160 some bucks for a new one on fleabay
        D, not good here. The corps of engineers opened the flood gates, literally. That has completely knocked out or water supply, there treatment plant, pump station and wells are all under a water. A lot of it. Zero running water. Not having running water is a bigger disaster than the flooding we got. Could be worse though, could be bleeding and not have running water. Not dead, can't quit.
            Hang in there your in our thoughts
            • #21
              I figured out what pot value for this machine.
              Its a 10k ohm pot,whick happens to be in the new harbour frieght vulcan tig pedal
              Which i picked up for 79.99 plus tax,it has an all metal case.
              The internals are plastic.
              The new syncrowave 250 at work has an ALL PLASTIC pedal,so this should work!
              • #22
                Did you ever confirm who made your machine?
                • #23
Name:	ESAB Heliweld 5.jpg
                  Tigerchevelle,
                  Your machine appears to be made by ESAB.
                  EWP 1341- 0300
                  Since you mention it uses a 6 pin rectangular Cinch-Jones plug, this remote may be the correct one.
                  Miller Dynasty 350, Dynasty 210 DX, Hypertherm 1000, Thermal Arc GTSW400, Airco Heliwelder II, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, etc.
