Hello everyone! Thanks for having me on the forum here. I've been a long time Miller owner and sadly my trusty ol' 2003 Miller Syncrowave 180 SD (SERIAL NUMBER: LC650711) (CC AC/DC Squarewave Power Source) has died...well, at least the TIG operation on her did. I'm the original owner and only use her part time as hobby so she really does not have a lot of weld time on her. I'm pretty sure her main control board (PC 1- I believe it may be called) has called it quits. I'm hoping that someone may have some suggestions on some items to try that I may have missed before shelling out some bank for a replacement board that's looking pretty costly at this point ($600-$700). Things I've tried:
1. I very rarely ever used the stick operation on her but I tested to see if that still works and it does very nicely.
2. I've disconnected each and every electrical interconnect in the welder and used electronics cleaner and conditioner on each connection with no change.
3. I've thoroughly disassembled and checked her torch from the torch all the way back to the welder connect with no issues found.
4. I've thoroughly disassembled and checked her gas line from the tank to her final torch connect with no issues found.
5. I've tested the output functions of her foot controller with no issues found.
6. I've tested the A and B contact points from the foot controller interconnect to the controller circuit board with my multimeter with no issues.
7. I've removed the main controller circuit board (Miller assembly number 213996) and reflowed all board connector solder joints.
8. Despite functional test of the foot control interconnect and went ahead and soldered all of the contacts with no change.
9. I've checked and tested the welders incoming voltage at the welder both turned off and powered on with no issues found - all looks good (also I've run another welder off this circuit with no issue)
10. I've checked her spark gap for proper clearance - cleaned, rechecked and looked for any signs of issues with none found.
11. I've performed a visual inspection of her main control board with nothing seen in terms of obvious burned resistors, caps, etc. I'm not a component level troubleshooter sadly.
Any other ideas of what I might try would be very appreaciated! Maybe something simple I've over looked? Thanks in advance everyone!
Tommy Graves
Tommy Graves
