I'm trying to get the right set up for my Diversion 180 to repair a 4R70W Ford Trans bell housing -- 2" x 3" part broken off at the end of the bell housing where the motor mounts up. Trans bell housing looks to be (roughly) 3/8" in thickness .........settings:
A/C 120hz (preset)
Balance 72 Neg (preset)
Max setting on amps --- 3/16"
I talked to Christian at Crown Alloys and he recommended either the R 4043 or R 5356 filler, but I'm just not sure since I have no idea what alloys Ford used in their transmission bell housings in 2002 (year of the vehicle).
Since my Diversion 180 -- running it at 240V only goes to 3/16" I'm going to do a multi-pass ....................anyone see any problems with the 180 doing a multi pass on a (roughly) 3/8" thick cast alum bell housing and which alloy from Crown would you recommend?
A/C 120hz (preset)
