I have a MM211MVP that came with a spoolmate spool gun. There are settings for 4043 wire on the chart in the door but I have never found them (on the door, searching online...) for 5356 wire.
Does anyone know where to find them? Even a chart from another welder that shows both 4043 and 5356 settings on the same chart (so I could have some idea how to change things to get them in the right range). Stuff happens so fast with aluminum (typically feeds are maxed out...) and things are different enough from what you're used to with steel that it's hard to get things setup unless you have some idea what should be close and when you should be searching for a different problem besides welder settings.
