Tig torch problem
  • Tig torch problem
    I have a CK Tig torch that has the adjustable head.
    The problem...... It is almost impossible to tighten the tungsten down.
    I screw the cap on as tight as I can but often I can still push the tungsten in with my finger.
    I have tried a new gas lens, and a new collet, but it still is loose and takes great effort to get it tight. It is like the tungsten is undersized.
    The problem just recently occurred and I cannot figure what to do.
    Thanks for all opinions.
    Perry
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    HTP 625 Micro Cut Plasma Cutter
    Victor O/A Rig
    Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
    10 inch South Bend Lathe_3 phase
    Baldor Double Cup Tool Grinder_3 phase
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
    Cyclone 2ft X 3ft Bead Blast Cabinet
    Quincy 325 2stg- Air Compressor_3 phase
    Graymills Built-in Parts Washer
    Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
    Mine did that just the other day and a little plastic part on the end cap was cracked. On mine, the trouble was the small plastic ring that samiches the O-ring with the plastic body of the end cap. Cracked right in half that little sucker was. Ended up putting on a new end cap and the world was great again. Also might just be the end cap itself doesn't fit well, since you tried different collets and collet bodies, try a different end cap.
      Without pics of all the pieces, we would all be guessing.
      Heck the other day I was having the same thing and I had the collet backwards.....how stupid is that ??!!
      Miller 30-A Spoolgun
      Miller WC-115-A
      Miller Spectrum 300
        Yup, something is backwards, broken, worn, or the wrong size.
        HTP Pro Pulse 300 MIG
        HTP Pro Pulse 200 MIG x2
        HTP Pro Pulse 220 MTS
        HTP Microcut 875SC
          Perry
          Find your torch model & gas lense in the CK book...........
          then compare parts diagrams....
          As said .... probably a part missing or out of order
          http://www.ckworldwide.com/Catalog_E.pdf
            Try a new collet. I have had that happen at work...Bob
              Thanks Ryan (and all of you guys) for the comments.
              Ryan was correct...... I had a cracked cap which failed to tighten down on the collet.
              Coolmate 3
              Victor O/A Rig
                Glad you got it figured out & fixed..................
