Is there any advantage to having a multi voltage welder if you will not need to move it?
The Miller 190 runs on 240v and the Miller 211 runs on both 110v and 240v. Other than being able to run on 110v is there any other advantage to having a dual voltage machine?
Is there a time when 110v would be better? I am assuming the 190 and the 211 are the same machine except one can run on dual voltage.
If you are running the 190 on 240v can't you just turn the power down to the same level as the 211 would be running on 110v?
