(can't seem to edit the post title but auto-correct changed "tig" to tin)
Hello All. Im fabricating another batch of planter boxes in 1/4" 5050, but I'm having major cracking issues this time around. Though the one I've attached a picture of is a funny shape, most are rectangles. All have a 32" long butt joint in the middle, joining two halves. The client wanted all bent corners so moving the joint to the middle seemed a good way to go. Last time however the joints were at the corners, and as some of you may remember, i did a series of shorter (2" or so) welds into beveled out areas.
Im first cutting a vee on both sides of both pieces (about a 1/3 of the depth) then butting the parts and clamping them down to the table. I make a series of short welds, about 1" long, about 5" apart. Then i flip the box and do the same on the other side, clamping bars across the surface to hold everything flat while it is off the table.
Settings and details:
Sync 250, #20 water cooled torch, 210 amp setting, ac polarity, ac balance 7-8 toward max penetration, 100% argon, 1/8" 2%lanthinated tungsten, 1/4 - 5/16" stick out, #8 and #10 alumina nozzles, medium gas lens, 15 second post flow, trying both 5256 and 4043 at 3/32"
The welds for the most part look good and go down smooth and shiny. The tungsten is staying well shaped and silvery. But when i flip the part and weld the other side, i crack the welds on the first side. Ive managed to get one of these together by doing very short welds, and grinding out cracks (with a carbide burr) and re welding, but there likely is some way to make longer welds and not get cracking, no? It seems like the longer my welds are, the hotter the part gets (obviously), the more the other side cracks.
Any advice is greatly appreciated.
