Can anyone shoot me a picture of the wiring to the coil on a 1994 or any compatible year onan 16 Bobcat 225g. It would be greatly appreciated . thanks
225g rebuild
I don't have a photo but the red lead from the ignition module (mounted behind the flywheel) goes to the (+) terminal of the coil and the black module lead goes to the (-) terminal of the coil. The black wire #47 from the engine harness also connects to the (+) terminal of the coil.
Under NO circumstances should you connect #47 or any battery (+) voltage to the coil's (-) terminal or you will destroy the ignition module.
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
Do they go 12VDC(+) while cranking?
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
