After coming across a brand new tig torch that was to be tossed, I decided I would take up TIG to add to my self taught welding knowledge. So borrowed a 20 cf tank and got it filled with pure argon, hooked the torch to my little 80a inverter ground down my tungsten and decided to give it a go. I get the general idea of TIG but am having trouble starting and maintaining an arc. Every once in a while I get a decent arc going but the rest of the time I get little "fingers" leaping to my work piece. I decided to video myself and see if any of you have any tips for a complete and utter newb. Right at the start of the video you can see what I mean, then closers to 0:25 I get an "eh" arc going. I'm running 80amps dce- and 20-25 cfh argon. Any help is greatly appreciated
TIG newbie help
At first it seems like you are way too far from the workpiece and you were just getting the high frequency arc.
What kind of tungsten?
How did you grind it?Ryan
DYNASTY 350 w/Wireless pedal
COOLMATE 3.5
CK WF1
SPECTRUM 375 X-Treme
(2) DIGITAL ELITE helmets
Weld-Mask goggles/hood
OPTREL e684 helmet
SMITH torches
HARRIS torches
Way too long of an arc. Also looks like you're free handing the tig torch. You need to brace your hand on something. Nothing wrong with scratch start, I use it fairly frequently for repair and fab work. Lots of quality work being done all over the planet using the scratch start method. Obviously not the best way to start and stop a tig arc, but certainly a good skill for carbon steel work. <br />
<br />
Keep a tight arc, watch the metal puddle before you move, watch your torch angle, just a slight tilt backwards will do. <br />
<br />
Now go get some tig rod and prepare to outgrow your setup with just a little practice.
As mentioned, arc length major problem.
The arc cone should be small, relatively speaking. It shouldn't "fan out" all that much. Have a look at this pic. Obviously it is enlarged, but it gives you the correct perspective with regards to the arc cone. Of course the arc cone will vary with amperage applied, but it should be "within reason"
HTP Pro Pulse 300 MIG
HTP Pro Pulse 200 MIG x2
HTP Pro Pulse 220 MTS
HTP Microcut 875SC
Alright took me a week and a half but I've been trying lots of things from youtube and a text book from my local cc and none of them are bueno.
I played with arc length and amperage and different size tungsten and etc, but I get the same result, if the electrode is anywhere within about 1/2", it just gives me that high frequency looking stuff, but if I pull away 1/2" or more, I get a really strong, obviously very long, arc. Could my little dc inverter be causing the problem or any other tips for me?
Originally posted by ryanjones2150 View PostWhat machine are you using? What is your setup like?
this machine with a simple tig torch off another Hft machine, a 20cfm 100% argon bottle at 25cfh
