Hi Friends, is posible to connect and work fine a S32 wire feeder with a phoenix456? or i have to go back and hook it up with the miller 250?
Thanks in advice friends
Welcome, ylopez. No one seemed to be answering so while I have no direct experience with that machine, I do have an older, less capable S22P12 feeder that plugs into the 14 pin connector on my trailblazer. Works great. Your S32 is more capable, has voltage sensing, and I would think should plug right into your Phoenix. Why not give a call to Miller tech support and confirm? Great people there. Just dial 1-800-4AMILLER and ask for tech support.
assume you have the manuals for both the welder and feeder? If not they are available under the SUPPORT link on this site.
Reason: Added info.
