im going to look at a 350p it has been refurbished today, the shop is good, is there any year 350p's that have bugs o stay away from? and this machine I think has had some new board or boards installed this month so would new boards update the machine and not have the bugs to worry about, I will be using this for steel and putting he alumapro gun on?
also, for aluminum, I've read that the pulse will not work with a spool gun, only with the push pull gun, so im leaning to the alumapro push pull over a spool gun, a couple more opinions on that would be nice, should I stick with the 15ft cable length, or will the 25ft run thin wire fine, for aluminum I will mostly be doing .125 thickness so im assuming ill mostly be using .035 wire (i don't think it will run .030 anyhow)
Also I will be learning to mig with this machine, I've been told this is a pretty technical machine to learn with, I can use my tig machine (Im no pro)
thanks for your help
