Need some advice on the adjustment of the resistor I just replaced in my Foot Pedal model RFC23-A it's an oldie but parts are still available. I was told by a repair guy that is Miller trained, that the brush that rides along with the linkage in the foot pedal should not come in contact with the wire wrapping around the resistor or it will burn it out again. I adjusted the brush with a gap of .030 and it will maintain a stable arc but it will not vary in current at all. Very frustrating. It's a great machine and I'd like to keep it running.
Foot pedal resistor adjustment
far as I know the slider brush must make contact with the resistor windings
I just took mine apart a few months ago and put new wires on it, I can say without a doubt that the brush rides along that coiled wire. Whether or not it's supposed to....no idea. It was like that when I took it apart and I left it alone. Works just fine. I can't see how it would work without touching. Having an arc gap would get pretty hot I'd think. Granted, I did not even look to see if there is a gap, but by the wear mark on the side of the wire coil, I'd say it's touching. I have a book on that foot pedal and can look and see if there's anything in there about it.
Thank you so much for your input. I took the burned up resistor to work and asked an electrical engineer buddy, and he said the same thing. How could it work unless the brush wasn't touching it. Then he went into about 30 minutes of yada yada yada. Also, I was thinking if, a desired gap where to be kept, a whole bunch better design aspects should go into this pedal, rather than a piece of angle iron holding the main linkage arm together. I would like to hear more from some one at Miller because I'm finding nothing in terms of a gap setting. Also I'd like to say that this is the first component I've had to replace since the time of purchase of the Dialarc HF-p in 1984.
Yes the brush rides on the windings. It's the metal linkage arm the brush holder is clamped to that must not contact the winding or it will short out. That's what the Miller trained guy meant.
You also want to adjust the brush holder so that it clears the winding by at least 1/16" (my personal spec) thru the entire travel. This keeps adequate spring pressure on the brush so it doesn't arc as it moves across the winding.Last edited by duaneb55; 02-22-2017, 08:46 PM.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
Originally posted by duaneb55 View PostYes the brush rides on the windings. It's the metal linkage arm the brush holder is clamped to that must not contact the winding or it will short out. That's what the Miller trained guy meant.
MIne was doing the same thing as was told to me most shops where these things were used are not the cleanest places mine was loaded with junk, so after cleaning it all and resetting the brush I hot glued some fiberglass window screen behind the vents in the pedal box. Hopefully this will keep the bulk of the dirt and crud out.
