stainless with a 350p and spool gun?
  • ryanjones2150
    I think you'd be better off to use the argon/co2 mix as opposed to pure argon...provided trimix is unavailable.
  • aametalmaster
    You can use a little spool in your 350 now. Just remove the 1/2 nut and pull off the big plastic spool holder...Bob
  • overkill 19
    And no have not welded stainless before.
  • overkill 19
    I just figured id use the spool gun, as i assumed it would be cheaper to buy a smaller spool, plus argon is rigged up to that side anyway.
  • ryanjones2150
    Why do you want to use a spool gun? Why not just use the 350 how you'd normally use it? <br />
    <br />
    Without the correct shielding gas, your weld will be sooty at best. I've done it before and have not been pleased with the result. <br />
    <br />
    TIG is the clear process of choice if you can. If not, run that wire through the 350 and not the spool gun. <br />
    <br />
    Have you welded stainless before?
  • overkill 19
    Thx guys, I'm a hobbyist at best! Id like to learn how to tig one day! <br />
    All im doing is cutting the end off SS handle "the rectangle" part the mates to the valve stem. Then welding a ss pipe to it and a T Handel on other end.
  • H80N
    Originally posted by gnforge View Post
    Yes will work but not high quality. 350 has induction adjustment. I keep a roll just in case. And have used it with argon. <br />
    But Tig in most all occasions
    TIG it if you can.............
  • gnforge
  • overkill 19
    You are going to want a "Stainless TriMix"
    The shielding gas recommended for short-circuiting welding of stainless-steel contains 90% helium, 7.5% argon, and 2.5% carbon dioxide. The gas gives the most desirable bead contour while keeping the CO2 level low enough so that it does not influence the corrosion resistance of the metal. High inductance in the output is beneficial when using this gas mixture.
    Will pure argon work? I have 2 inchs of weld to do. I have a bottle of that and reg mig mix Co/argon mix
  • MAC702
    ...High inductance in the output is beneficial when using this gas mixture.
    How many wraps of the work lead around the table leg would that be?
  • H80N
    Originally posted by overkill 19 View Post
    Can it be done?
    Im making a ball valve handle extension.
    Can i buy a small spool and mig this?
    What gas works best?
  • overkill 19
    started a topic stainless with a 350p and spool gun?
    Can it be done?
