Quick question about fillet welds
  • Quick question about fillet welds
    Deleted
    More information is needed
    are you welding to a code?
    "welding a beam" can you tell us what this part/fabrication is? a bridge, a building or a catwalk? or...?
    what about your customer, can they answer this?
    Richard
    West coast of Florida
      Your weld detail calls for 9mm weld on this joint. thats what you need to put on it.
      For myself, 3 average size passes with a 1/8 7018 rod gets me 8mm. You need 9mm, judge and weld accordingly.
      Multi pass fillet welds can be done any size, you just need what your weld detail calls for. Going a little over is ok, going under the weld detail spec is not ok.
      For Your weld detail, 3 passes with 5/32 7018 would suffice.
      Lincoln Idealarc 250
      Miller Bobcat 250
      Thermal Arc Hefty 2 feeder
      Thermal Dynamics Cutmaster 52
      Torchmate CNC table
