I recently bought s Starfire 2e and there seemed to be no power. The motor is fine but when I picked it up there was power and he struck an arc. Upon further inspection I notice that a wire from capacitor was not connected. I connected it to where I thought it should go but still no output.
Starfire 2e
There is a fuse in the exciter circuit you should check. If you don't have the manual you can get one here:
https://www.millerwelds.com/support/manuals-and-parts
please post your serial number.
Based on that date, your ser no should start with JE, and should be on the welding generator, not on the engine. I'm guessing this is the correct manual.
https://www.millerwelds.com/files/ow.../O464C_MIL.pdf
Also make sure the slip rings are clean and brushes are not chipped or cracked ,clean slip rings with 320 grit paper brushes can't be less then 1/4 inch also make sure the engine is at the proper rpm at weld speed.And clean the contacts were they connect to the back of the switches on the panel .
Finally home and thanks to everyone that has responded. The fuse was good, now trying to decipher wiring scheme. So far from the brushes are wires #25 & #26. They go to the rectifier which in turn goes to the capacitor. There is a fuse wire #28 going to rectifier. Then there is 2 wires coming off rectifier one is the #8 and it goes into generator bundle and the other is #27. When I got the welder #27 was taped closed. There are also a #9 & #10 wire un-connected which by the wiring scheme either should be connected depending on excitation. When I first took cover off when I got it home the capacitor wire 26 was dangling but I couldn't tell where it connected to
Not sure if it's something weird with my iPad, but part of your post reads..."So far from the brushes are wires #25 & #26. .....". What should that line say? Not sure where the & came from. Same thing shows up other places in your post.
You say #25 and 26 go to the rectifier and cap. That is correct per the diagram. 25 should go to the plus side and 26 to the minus. I don't understand the note about excitation on the diagram--I know what buck and boost mean, and can infer a meaning here, but not sure if it's correct. Maybe someone can enlighten us. #27 and 28 should be hooked to the "AC" terminals on the diode bridge. Assuming "normal" excitation, wire 27 should be tied to wires 8 and 10. Wire 9 should not be connected. Not sure where the wire 27 connection to the others is physically located. You'll just have to search. Try these connections and see if it works.
Originally posted by D Auger View PostSo is there 3 ways to wire this machine for excitation according to the diagram ?interesting
