Let me just say I'm VERY rusty when it comes to Mig and I've never trusted the welding process over stick welding for making strong welds on thick material, but that is probably because stick welding is like riding a bicycle to me when I walk away from it for years.
Anyways, have a new MM252 bought in 2013 and only used maybe 1/4lb of the wire on it in that time. Seemed like it wasn't feeding right when I first started it all up (rollers just slipping) so thought maybe the wire has an invisible to the eye oxidation I can't see causing the lack of roller traction??? Not sure so for ~$30 thought it wasn't worth my time. Bought a new 5lb of Hobart .035" solid wire for the welder yesterday late afternoon and started piecing together a 3/16" steel box. Going to have a go at making my own gun safe.
Now I'm use to burning in 5P 6010 and running cover passes with 7018. Those are my favorite 2 rods I've been using since I was like 14. But with Mig I under stand you have a pretty weld with no penetration, so I fear these welds may be some of those.
Not sure why, but the MM252 settings table for 3/16" steel
18.4V at 265 ipm
contradict the Miller Mig welding calculator. by saying I'll need a LOT more wire feed speed? Short Circuit Transfer
Wire Size & Wire Feed Speed:
.035" (0.9 mm) at 320-340 ipm Shielding Gas & Voltage Range:
75% Argon/25% CO2: 18-19 Volts
These welds just seem like they are hanging off the material too much. I don't seem to have this problem when I'm mig welding flat, but this is more horizontal overhead? I just want this too look nice and smoothed out rather than the bead being so high like this?
I tried doing different combinations up to 19V and adjusting ipm up to 340, but can't seem to find the right settings I'm pleased with.
https://app.box.com/s/4oh267b0gs5n3jhbwydzxhwle1gx5226
Here are a few pics of the welds. Also, using 'new' 3/16" plate from the local steel supplier in town.
https://app.box.com/s/xc642oec7ttse2w3nudtddklkqnvg49p
https://app.box.com/s/tlb3j867ixlyz0gpanu963cmyzcwtliw
https://app.box.com/s/iaql01ywhv6jpzizzvigzhnlfz63nt77
Any thoughts on how I can get better penetration? If my Airco wasn't acting up, I'd be welding this out with 6010 and 7018.
18.4V at 265 ipm
