I was wanting to know if millers wireless foot petal will work with my setup because it is not listed on the fitment list. Im running a shopmaster 300 with hf251d and a weldcraft LS17 torch with the amperage control built in. I like the torch for certain things but it is hard to adjust with gloved hand and stay steady so wanted to know if i could use that same torch just unplug the 14 pin connector and hook up the wireless foot petal. thanks
wireless foot petal for hf251d on shopmaster
If a particular machine/setup isn't on the compatibility list it means it just hasn't been tested by Miller (or it's actually known to be not compatible).
As the Shopmaster 300 is based on the Syncrowave 250 and the SW250DX is on the compatibility list it may work but a call to Miller will likely get a "not recommended" response seeing as the SM300 isn't listed. ???MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
