TIG water cooler opinions
  • #46
    Huge price difference between the brass and stainless pumps. I think I'd prefer a stainless one, but you can dadgum near buy three or four brass pumps for the cost of one stainless pump.
    • #47
      IMHO.....brass ones are fine.... probably outlast both of us
      but it is your dime ....
      food for thought:
      derating the pump from 250 PSI down to 50 PSI reduces its load by 80% ....further increasing pump life
      • #48
        I have a couple of motors laying around, but it looks like it's not too awfully more expensive to just get one thats already together with the motor, pump and adapter.
        • #49
          best to buy pump & motor already mated ........... motor usually 1/3 HP..... and use an unusual slotted coupler
          bound together with a band clamp...... slots on both pump and motor shafts.... motor end bearing carrying the major load
          • #50
            Heiti, you are the man! Thanks for all the knowledge you share.
            • #51
              Bah...HumBug......!!!!!..........
              • #52
                I don't like Xmas either.
                • #53
                  BH....got the flow gauge...and the other stuff. That was very generous of you and I appreciate it. Did you weld that tube up? Very nice work if you did.
                  • #54
                    Just don't forget about always considering the effects of dissimilar metals.
                    You get copper, brass, stainless, bronze and aluminum, plus whatever is in your power cable, all soaking in a electric bath.
                    Miller 30-A Spoolgun
                    Miller WC-115-A
                    Miller Spectrum 300
                    • #55
                      Hmmm....probably going to end up with all of that now that you mention it. You have any trouble with that in your shop? Surely whatever coolers you use has a mismash of metals in it. I never thought about it like that though.
                      • #56
                        the commercially built ones use a similar mix of metals .... so both on about the same footing
                        and....would think that low conductive coolant would minimize electrolytic problems
                        • #57
                          Ryan,
                          Glad you can use the goodies.
                          The square tube was a practice piece using the ti strips.
                          I'm ok tigging titanium but terrible with aluminum.
                          Need to practice more...............
                          I use 50-50 auto coolant in my cooler and change it every year.
                          Here is info on coolant from Miller.
                          Coolants
                          Sold in multiples of four in 1-gallon recyclable
                          plastic bottles. Miller coolants contain a base of ethylene glycol and deionized water to protect
                          against freezing to -37° Fahrenheit (-38°C) or boiling to 227° Fahrenheit (108°C).
                          Low-Conductivity Coolant
                          (clear, pre-mixed) 043810
                          For TIG and MIG applications. NOT for use in push-pull systems or systems
                          where aluminum is in coolant path/circuit.
                          Aluminum-Protecting Coolant
                          (green, pre-mixed) 043809
                          Primarily used in push-pull systems where aluminum is in coolant
                          path/circuit and high frequency is NOT used.
                          • #58
                            food for thought:
                            Are you sure about this? I'm asking a question, not claiming to have the answer.
                            I relate this to a problem I had many years ago: My in laws had a tennis court about 60 feet of elevation above Otter Creek. They had a centrifugal 1/2 HP pump to push water to it. Pump motors would fail in about two years. There was no pressure tank. When they needed water, they opened a valve at the court. The pump ran in slow cycles building pressure, shutting off. The head the pump overcame kept the switch from cycling too often or moving much water. I went to the pump expert at FW Webb plumbing supply. His solution: turn up the pressure switch.
                            Higher pressure meant less volume from a centrifugal pump. It would shut off when the valve at the top of the hill was closed, but with valve open, it ran continuously. Playing with it I discovered that at higher pressure, lower flow, motor current was significantly lower. As he explained, "The work a pump performs is to move water. Moving less, means less work."
                            Willie
                            Dynasty 280DX
                            Bobcat 250
                            MM252
                            Spool gun
                            Twentieth Century 295
                            Twentieth Century 295 AC
                            Marquette spot welder
                            Smith torches
                            • #59
                              Willie
                              OH!
                              I have a very expensive welder, my torch is well into the hundreds, the cooler cost so much, I'm embarrassed. I will not risk a problem by using automotive anti freeze. $28 anti freeze is what is recommended. I will pay the price.
                              Dynasty 280DX
                              Bobcat 250
                              MM252
                              Spool gun
                              Smith torches
                              • #60
                                Willie
                                the Procon Vane pumps are positive displacement..... Whole different animal than centrifugal
                                BTW..... that brass Procon vane pump is the same as the one that came with my $10K Dynasty 350DX Tigrunner
