TIG water cooler opinions
    Originally posted by ryanjones2150 View Post
    That's actually a dadgum good idea. Helga also has a 115v outlet under her skirt. Come up with a little control panel, a flow indicator as was suggested (excellent suggestion by the way) and I'd be off! I certainly have a radiator or three laying about. You don't reckon it would restrict the air flow from Helga too much do you?
    mount it on standoffs..... excess flow will escape out the sides without creating backpressure
      A quick fleabay search revealed to me that those carbonators are cheap and plentiful. Even new ones aren't too pricey. Seems pretty straight forward.
        If you do use a car rad..... make sure it is REALLY clean or new.... you don't want to push rust scaley crud through the pump and torch
        an inline water filter at the pump intake would be suggested too.... I like the clear lexan ones
ID:	578145 Click image for larger version
          Clear Polycarbonate Filter Housings
          can be had pretty reasonable $22 bucks
          http://www.ebay.com/itm/Clear-Polyca...EAAOSwe7BWxL8D
            Helga has an ample backside with fan....... you could use a car radiator... it could be both reservior and cooler in one......
            If you use a car radiator-you can also use one of the radiator mounted electric fans like the cars have now. That would force air through the radiator for additional cooling. A 12 volt battery with an inline fuse, and a battery charger. Good to go.I
            • #21
              I put a sight glass on the front of my tank to see water level and flow. Have the return, feed in thru the top of the sight glass. will try and get some pic's for you . Machine is at my son's shop across town. O and yeah I've lost a few of those clear nozzles to dropping, it is there biggest draw back. But in tight spaces they are great, you can look thru them and see what you're doing.
              • #22
                Originally posted by Oldgrandad View Post
                I put a sight glass on the front of my tank to see water level and flow. Have the return, feed in thru the top of the sight glass. will try and get some pic's for you .......
                could add an extra sight glass in the tank with a bright UV LED... would backlight nicely.....
                especially if you are running UV dyed coolant..............
                • #23
                  Why not use a small $2 fuel filter like they use on small 2/4 cycle engines? You can buy a cargo-container's worth for like $15. And don't give me the "china" excuse, I bet everyone's oil filter on their vehicle is made in china! But seriously, you can likely buy 10 for $10.
                  HTP Pro Pulse 300 MIG
                  HTP Pro Pulse 200 MIG x2
                  HTP Pro Pulse 220 MTS
                  HTP Microcut 875SC
                  • #24
                    those are "FUEL" filters and may not fare so well with water based coolants..............
                    I would use some form of WATER filter that can flow at least 2 liters per minute
                    • #25
                      How so?
                      HTP Microcut 875SC
                      • #26
                        How so?
                        pleated paper..??...............they might fall apart and clog / bind up the pump..... I would rather use a wound yarn water filter .........................
                        • #27
                          [ATTACH=CONFIG]n578310[/ATTACH]
                          How would that be any different from when being used as a fuel filter? Plenty of fuel filters use pleated paper with gasoline running through them. I still fail to see how it would be that detrimental to run tig coolant, but ok, I'll retract my suggestion.
                          HTP Microcut 875SC
                          • #28
                            I could do what lots of others have done, but where's the adventure in that. I like H80N's recommendation of a small-ish car radiator in front of the exhaust fan on Helga. Someone else had the suggestion of using standoffs to make sure Helga is breathing well.<br />
                            <br />
                            So the radiator would be the reservoir as well. Pretty much need a procon pump and a filter then. Hang the radiator on Helga's back, build a small control panel with the flow meter, temp and probably some lights and things. In the end, if it doesn't cool good enough, I can always reconfigure to a smaller radiator with a separate fan and a holding tank. <br />
                            <br />
                            What's the normal operating temp? I guess a better question is what should the water temp stay below to still give adequate cooling? <br />
                            <br />
                            Maybe one of you guys can come take pictures for me, I'm horrible at photo documenting my projects.
                            • #29
                              As promised here's the picks of my cooler. The space behind the tank was meant for the radiator that never got put in and the pump. The current pump is on the bottom of the cart next to the gas cylinder.
                              • #30
                                REALLY Nice build.....
                                how many gallons... ???
                                3 gal seems to be a good number on a 300 amp machine
