I have a miller aead. I set the weld rpm to 3000. When i start to weld with the rpm drops down to about 2000 to 2400. Any ideas about what the issue could be?
Miller Aead rpm
Are both cylinders of the Onan firing?MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
Have you attempted any basic troubleshooting?
is there a fuel filter in the fuel system?
is the fuel tank cap venting properly as it should?Lincoln Idealarc 250
Miller Bobcat 250
Thermal Arc Hefty 2 feeder
Thermal Dynamics Cutmaster 52
Torchmate CNC table
- Likes 1
As Mchevelle suggested - perhaps a governor issue.
I've seen weak speed springs allow for excessive governor droop or perhaps the spring is anchored in the wrong governor lever hole affecting its sensitivity. Moving the spring anchor point closer to the governor operating shaft will make it more responsive. Too close and the engine will surge.
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
