Hello all, I'm new to welding. Just bought a flux core welder. When welding, does the wire actually touch the joint or do you need to just have an arc? Also how do you strike the arc? Thanks in advance!
Flux core newbie
You'll answer your own question as soon as you pull the trigger. Feed the wire out of the nozzle about 3/8". Touch it to the joint and pull the trigger. The wire will burn off immediately to the arc length, which you then fine tune with the adjustments on your machine.
Originally posted by ryanjones2150 View PostI have not heard one single good thing about any of the horrible freight Welders. It may make a good door stop.HTP Invertig221 D.V. Water-cooled
HTP Pro Pulse 300 MIG
HTP Pro Pulse 200 MIG x2
HTP Pro Pulse 220 MTS
HTP Microcut 875SC
This is curious. You made significant modifications to a cheap machine before you even used it? More power to you, but I do find it interesting! At your level, the wire isn't going to make a significant difference. What you need is arc time. Start welding with what you have. Then you will really know what questions to start asking.
And my .gif above was just a funny. I will always help anyone regardless of their machine.
I've built plenty of stuff with HF welding wire. Yes, the Lincoln Innershield is better. Don't worry about it yet.
