im new to this type of machine with the amphenol socket and trying to find out anything i can about it. it is a miller arc pak 350 with a 14 and a 17 pin connector and a toggle switch for switching between the two,.i am looking for any info and part numbers on anything that will make this weld. i was told at first that the impossible to find 17 pin pendulum? or a miller rch-14,or a miller 22a/24a wire feeder, or i read in a post to jump 17pin(a,b,f) to 14pin(c,e,d) if so would i then jump 17pin(c) to 14pin(m) and then run any 14 pin control. would first like to find the easy way to see if it even works any info is appreciated thanks
arc pak 350 questions
Plug in your serial number here for the manual
https://www.millerwelds.com/support/manuals-and-parts
