I have been looking for slip on tube elbows & can't find a source. The elbow seems to be the same diameter as the tube but has swagged ends to slip inside the tube which is approximately 1" id with about an .060 wall. Looks like the tube is 1" EMT or very close. Radius seems about 2" or 2.5", swag is 3" long. I have looked all over the internet & no luck. I thought they were just fence parts but nothing there either. Any help will be appreciated. Looking for maybe 20 pcs. If it was just one or two I'd make sleeves but for 20 I just want to buy. Thanks.
Looking for elbows
Looking for elbows
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14Tags: None
These are the upper corners for spring loaded tarp arms on a single axle dump truck. It is a very cheap/flimsy set up. The customer likes these as they are cheap in cost, easy to fix & they say it doesn't matter how strong they make them the guys destroy them all so why not just go cheap. Some other place came up with this idea but they can no longer find the guy. It looks like it uses all off the shelf items from Lowes or something but can't find the elbows. Here is one of there other trucks. This one is slightly different with longer springs than the I am supposed to fix now but gives you an idea. Looks like garage door springs. The one I'm fixing they just cut the springs to whatever size works. These trucks are all in poor shape.
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
Originally posted by MMW View PostI have been looking for slip on tube elbows & can't find a source. The elbow seems to be the same diameter as the tube but has swagged ends to slip inside the tube which is approximately 1" id with about an .060 wall. Looks like the tube is 1" EMT or very close. Radius seems about 2" or 2.5", swag is 3" long. I have looked all over the internet & no luck. I thought they were just fence parts but nothing there either. Any help will be appreciated. Looking for maybe 20 pcs. If it was just one or two I'd make sleeves but for 20 I just want to buy. Thanks.
[ATTACH=CONFIG]n576500[/ATTACH]
have you called a big supplier like Hoover's....??
http://www.hooverfence.com/catindex.htm
Originally posted by Bls repair View PostWhat you could do is get a straight 90 ,find pipe to fit inside,drill hole bolt together.You can do the same thing to replace or repair straight pieces
You could you exhaust pipe, but I've found that it bends up too easily, but if the customer wants cheap(I know how bad driver can screw them up and how fast), you could always call up an exhaust shop and see what they would charge to bend you up a bunch.
never mind I see you have those ******* small ones.
I use black iron pipe and threaded fittings to make my 90's and 45's. Quick, easy and makes changing out a section easy.Last edited by Lostone; 12-27-2016, 11:15 AM.
