Hello, new to the forum. I need a control board schematic for a Millermatic 135 (Serial#LE222177) part #207463, to diagnose a feed motor issue and just to have the schematic. Any help appreciated.
Millermatic 135 Control PCB Schematic
Thanks for response and welcome. I called Miller and they would not give me the schematic, said either the PCB is still in production or something relevant. Definitely MOPAR guy (1970 Coronet R/T). Hoping someone in here or a Miller tech may see and send it. Thanks again.
There's a tech manual on eBay now. May not match your ser no but might be close enough to be some help. There is also a new circuit board on there now.
http://www.ebay.com/itm/MILLERMATIC-...wAAOSwV0RXtwIV
Thank you for your input. That Technical Manual contains a basic block diagram schematic, not the control circuit board schematic. I have this manual. I will not buy a circuit board as I will fix mine with/without the schematic. Have been repairing electronic PCB's over 25 years.
- 1 like
Originally posted by hemi-1 View PostAeronca41, you may be right. I overlooked this is not an Owner's manual but a Technical Manual. I will contact the seller to see if the control PCB schematic is included. Thanks!
I hear you on fixes. I've been fixing things to the component level for 50+ years, up to and including mainframe computers, and find it very frustrating when I have to end up drawing my own schematics from the boards. That, of course, has become increasingly impossible with everything integrated into processor chips or gate arrays now, not to mention no longer having access to the necessary surface mount and hot air soldering equipment since retiring. Good luck.
Yeah-you had to make it yourself by rubbing a cats back with some high-dielectric strength cloth-and the cat usually didn't like it. :-)
hemi-did you get any info on that manual? I'm thinking it will be what you need.
Originally posted by ryanjones2150 View Post50+ years?!!<br />
<br />
...I didn't realize they had electricity back then...---Meltedmetal
