I've been researching this for about 3 weeks. I've visited local welding supplies and all I got was individuals thumbing through catalogs reading the same descriptions I've read multiple times. I've called Miller and spoke to somebody there and the person was knowledgeable but I think I have too many questions. Meaning he would suggest everything I researched but when he would suggest something I would ask about qualities of another machine.
I have a Millermatic 250x. 30 amp spool gun. I don't care for the spool gun size and weight. I like the mig gun.
I have a Lincoln Tig 200 Square Wave that's kind of cool. (I've only messed with it about an hour on scrap and nothing of importance.)
The Millermatic I can tell if it's me or the machine. It's just a pain sometimes getting a weld started without it popping back into the gun and ruining the tip. (I called support and they said it was a wire feed problem and to change the liner. I did and really no difference. Plus it does the same thing with the spool gun.)
I've kind of figured out a way to get it to start by running the wire out about 2" kind striking an arc then getting the torch down to the appropriate level to weld. Then when i get it going, it just seems the settings don't match the metal guide. Again it could be me.
All I know is a friend has a 350P aluminum setup and I went to make some aluminum brackets for an AC compressor, I put set it to the metal size, cleaned, hooked up the ground and welded. I never had welded aluminum and it seemed pretty easy.
So that's got me thinking. Welding is a hobby and a release for me and it's usually to fix a vehicle or to make something I want to tinker with. Having said that I'm not trying to turn into a professional welder. I'm not lazy but I don't want to spend hours upon hours learning all there is to know just to weld something simple together.
I foresee myself welding mostly steel but I do have some vehicles with aluminum bodys I need to patch up. I don't like the weight and size, hassle of the spool gun and loved the push pull gun on the 350p aluminum.
At first I was trying to go the multiprocess so I just had one machine but then I came to realize there aren't many/any MP's that do AC tig so that kind of killed that for me.
Tig is cool to tinker with but I prefer the mig. (I'll keep the Lincoln in case I need it something really thin.) But since I liked my only experience with the 350P aluminum, I was considering the non aluminum version really wanted to make sure if I dropped that much it would make me happy. Unfortunately I haven't found a place to demo one yet.
Calls to Miller, they recommended a 215 to a 252. But again when he started talking about those I started asking about pulse and things along those lines and articles I read how they can effect vertical welding etc. (Those may or may not be true.) That's where he got miffed and replied I had it all figured out. Well just the opposite, there is just so much stuff out there and so many freakin opinions which more than half I believe are now posted by individuals reading something online and posting like they are an expert. It's almost impossible to make an educated decision anymore.
I then called a local repair place. They told me to scrap the 350p idea, go with a XMT 304, add pulse to it etc and pick up the items used. and have about the same into it as a new 350p. He suggested I get my 250x tuned up and keep it.
So I started researching the 304 which caused me to know stumble on the XMT 350 MPa & Invision 352MPa. I then saw the Invsion 352MPa packages that come with a D74. A mig gun setup for steel and one for aluminum I can roll around my shop. But then I can't justify 12k to tinker.
Outside of the repair shop suggestion, I've realized everybody has just thrown out machine models and non really can answer why one over the other or why would get a XMT 350 over a 252. At best it's based on are you going to weld under 1/2" or more than 1/2". My guess the main reasons are longer duty cycles at higher amps but still I want to know about the pulse technologies and other things that may benefit somebody like me. If it saves me time and frustration, then I'll pay more for it.
With that, I don't like buying something small/limited and working up. I'd rather purchase more than what I need and never need it than just enough to get by now and wish I would have just got a better model to start with.
The values on these seem to hold fairly well so my thinking if I get a used setup and take care of it, it probably won't loose that much money if I ever want to sell it.
On that, I think I'm back to I want a setup I can mig steel and the ability to run a push pull gun on aluminum.
I love the idea of the dual feeder setup on one cart and I just pick what gun I need and go to work but I still have the 250x and if tune up solves the issues I'm having maybe I just need to go with a 350p and a XR gun?
I apologize for the length, I could probably type another couple of pages worth of ideas I'm contemplating but have tried to condense it down as best I could to give anybody reading this the mindset I have and my situation.
Anybody that would care to share experiences, and opinions with reasons as to why they would stick with the 250sx and go with a 350p. Or would you look at an XMT 304 or a 350/352 MPa and build it out. (If I go this route, I'll probably take my time and piece whatever I need to get together over time and get the few things I need to get done with my 250x and hold off on other things until I get what I want.)
Also, what's the true difference between the Invision line versus XMT. In particular, the 350 MPa versus the 352MPa? I ask because I see both come up refurbed on ebay and I can't decide if I should rule out one over the other for any type of reason. Thanks in advance for any ideas.
