I bought a Syncrowave 180SD about a year and a half ago, I am extremely unhappy with this machine. I don't know if there is something wrong with the welder or if this is as good as it gets. It seems to be very inconsistent, It never seems to weld the same twice. I am trying to weld 5052 aluminum sheet 0.070 thick, I have tried 4043 and 5356 filler rods. I have tried 3/32" 2%thorium and pure tungsten's. 2%thorium pointed works best. I clean with a scotch brite pad and follow with acetone. I don't like the wide arc that this machine produces. It makes dirty inconsistent welds. Its like I have to learn how to weld all over again each time I weld. There are no adjustments on this machine except for Balance/Dig, so it cant be a set up problem, and I have had an electrician check the incoming power with no problems there ether. This machine has been in for repair a couple of times, and the rep has even welded with it at my shop.(I don't think he knew how to weld) Every one gives me the impression that this is as good as it gets. Does anyone have any suggestions or ideas? I don't know what else to do.
This machine had a massive surging problem, (you would hear a large power serge, and blow a 1/2" hole in what ever you were welding) this was previously repaired. Has any one else had any problems with the Syncrowave?
