AEAD-200LE engine sputter
  • AEAD-200LE engine sputter
    Hi - I have an AEAD-200LE. It starts fine but then the engine randomly idles down or sputters inconsistently. Can you provide me with some guidance or help with resolving this? thank you very much
    Serial number PLS
    You may need to drill a small vent hole in the fuel cap
      My tractor does that sometimes, change the fuel filter if it has one, if it doesn't, take the fuel feed line off at the carburetor and blow air into it, go easy if it's shop air, no more than 5-10 psi. Sometimes crap gets built up in the fuel tank outlet and blowing a little air up there clears it out.
        When is the last time the engine was serviced? Oil/filter change, new air filter, new spark plugs and new fuel filter will do wonders and is inexpensive.
        Lincoln Idealarc 250
        Miller Bobcat 250
        Thermal Arc Hefty 2 feeder
        Thermal Dynamics Cutmaster 52
        Torchmate CNC table
          Make sure the carb is clean needle and seat are clean in the carb and the float is adjusted right .
            I have the same one
              Sounds like when the carb is full of fuel it starts right up but isn't getting enough fuel to continue to run. Is it time for the fuel filter to be serviced? Fuel tank dirty? Fuel line kinked?
                Did you get your machine fixed yet?
