Hello Hello,
I am trying to find an Aluminum wire I can use for hardfacing, I am not sure if it even exists but I have some aluminum cleaning equipment that has a feature where you push a pedal type of latch with your foot and it drops the brushes to the floor, then the brushes start as they hit the switch.
When its turned off, you push the handle up and it re engages the pedal type latch back on and keeps the machine straight so you can roll it without the brushes touching the floor. Hopefully I didn't loose everyone.
The problem I run into is the surface on the pedal latch gets worn and the piece it rests on gets worn, this makes it so you can't roll the machine without the brushes falling down. I tried welding them together and have been doing so for a while now and it lasts allright but I would like to do a better job if I can by getting some better, more wear resistant wire.
It sucks when you test it somewhere and you have it plugged in, the brushes drop all of a sudden and the machine starts running away from you, everyone looks at you like your crazy
The aluminum the pieces are made of is cast but its a very forgiving cast, been freely accepting 4043, 4349 and 5356 with no problem.
Anybody have any recommendations for an Aluminum hardfacing wire?
Thanks in advance.
Thanks in advance.
