Gas inlet to Multimatic Machine
  • Gas inlet to Multimatic Machine
    does anyone know offhand what the gas inlet fitting is to the 215? I'm trying to make a quick disconnect and don't have the machine nearby.
    Thanks.
    I believe its a 3/8" NPT, female in the machine.
    if there's a welder, there's a way
      Might be 1/2" or 5/8"...... Now I am not sure.
        It's definitely not just pipe. It a flared fitting.
          Well, yes... of course. But I am guessing you need the size of the pipe right?
          Im gonna bet my luck on 5/8" NPT, yes its flared but that's a given.
          Here is a random regulator, its got the 5/8" outlet connected to an 18" hose so I am pretty sure its a standard size in welders and regulators.
            Yes - It says 5/8" Female @ 18 threads per inch.
            Not an 18 inch hose.
              Lol, can't believe I missed that.
                NPT IS national pipe thread
                  Yes, and what are you trying to point out?
                    Thanks.
                    you want a 5/8" x 18 Right Hand "B" Size Male gas fitting (NOT NPT)
                    Might be best to buy the quick disconnect set
                    https://www.arc-zone.com/gas-hose-co...g?cPath=5_219&
                      IS NPT not just a designation for pipe thread? I am getting confused.
                        NPT stands for National Pipe Thread .... which is a tapered thread
                        That fitting is NOT NPT
                          Aaaaaah. My bad, I messed up, someone told me it was just a designation for a pipe thread, tapered or not.
                          Thanks H80N for clearing that up.
                            It can be confusing but a couple of things to remember
                            Inert gas fittings are usually 5/8" x 18 Right Hand " B" Size gas fitting
                            Coolant fittings are usually 5/8" x 18 Left Hand " B" Size gas fitting
                              Thats what I'm after.
                              Those disconnects are pricey. I was looking to find a end so I can use normal cheap air line disconnects. I have 3 bottles & regulators that I'm swapping around all the time and it's a pain.
                              Thanks for your help.
