New Tig torch
  • New Tig torch
    Last week I posted a problem with my CK Flex Neck Tig torch leaking water.
    The flexible neck had finally given up.
    The solution was to get a new torch and I decided to buy a CK FlexLoc WP20 water cooled torch with 25 ft hose.
    I have had a chance to use it a few times and I have to say it is by far the best torch I have ever seen.
    I regularly weld end caps on 3 inch diameter by 6 inch long Dom tubing with the tubing mounted in my lathe with a 4 jaw chuck.
    The torch is mounted to the tool post using a fixture I made for the torch.
    With this FlexLoc I can easily move the head of the torch to any angle I need, and I just rotate the lathe chuck by hand and fusion weld the cap to the end of the tube.
    These items are rollers for the motorcycle roller starters I make and sell.
    After welding both end caps on the DOM tube, I drill a 5/8 inch hole through both ends.
    Then the DOM tubing is moved to my rotary table where I weld in the 5/8 inch diameter keyed shaft for an axle.
    The new FlexLoc torch again comes into play with the adjustable angle head. Great torch!
    If anyone is needing a new torch I urge you to check the CK FlexLoc.
    No connection with the product here, other than that of a satisfied owner.
    Perry
    I Build and Sell Motorcycle Roller Starters
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    HTP 625 Micro Cut Plasma Cutter
    Victor O/A Rig
    Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
    10 inch South Bend Lathe_3 phase
    Baldor Double Cup Tool Grinder_3 phase
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
    Cyclone 2ft X 3ft Bead Blast Cabinet
    Quincy 325 2stg- Air Compressor_3 phase
    Graymills Built-in Parts Washer
    Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
    Perry, thanks for posting. "Real user" reviews are worth a lot!
      Great real review.
        Great to have a happy ending.....
        But PLS keep a spare torch on the shelf to avoid future downtime.....
