KH381136 225d plus bobcat. Hello I am working on another of my welders. The 225nt plus went down so I had to use the 225d plus for back up. Well today I went to start the 225d plus and the machine wouldn't idle up. I brought the welder to the shop to do some checking. It will idle up for maybe a second or two then remain at low idle. It try's to speed up if you turn the start switch to run or move the idle lock lever to run but nothing else. I unplugged the wires going to the idle selonoid and I have twelve volts there while the welder is running. I plugged the selonoid back in and it try to speed up then the selonoid drops back out. I am thinking the idle solenoid is bad or the idle control is bad. Has anyone ever had anything like this ? Any help would be great ty!
