Tig torch problem and I need advice soon......
  • Tig torch problem and I need advice soon......
    I am in the middle of a project welding aluminum plates and tubing.
    Suddenly there is water dripping put of the torch head.nozzle
    Knowing water and electricity do not mix, I shut things down.
    The torch is a CK (#20) water cooled torch running off a Dynasty 200 machine.
    Can someone tell me what may have caused the water to start leaking and where should I begin to find and fix the problem?
    Thanks for any help and I will have to pause on the project until I get it fixed.
    Perry
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    HTP 625 Micro Cut Plasma Cutter
    Victor O/A Rig
    Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
    10 inch South Bend Lathe_3 phase
    Baldor Double Cup Tool Grinder_3 phase
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
    Cyclone 2ft X 3ft Bead Blast Cabinet
    Quincy 325 2stg- Air Compressor_3 phase
    Graymills Built-in Parts Washer
    Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
    Perry...
    is that a Flex Head version CK-20.............??
      H80N,
      Yes, I failed to mention that it is a flex head. The flex neck is where it must be leaking because the water drips out of the cup.
      Perry.
      Coolmate 3
      Victor O/A Rig
        Originally posted by piniongear View Post
        H80N,
        Perry.
        Thought so...after extended use they sometimes crack along the silver solder joints.....Metal fatigue...
        time to go shopping for a new torch
          Thanks for your comments. The torch is only 2 years old but it has seen quite a bit of use.
          I am welding lap joints of 1/8 inch 6061 to 1/4 inch 6061 plate.
          I may just shut off the water cooler and try to finish the project with a non cooled torch.
          I am welding at 130 amps A/C so it is a borderline situation on if I can do this without cooling. Any comment on using no water?
          Thanks,
          Perry
          Coolmate 3
          Victor O/A Rig
            Thanks,
            Perry
            without water... it will likely POP... & Sizzle itself....Nearly Instanter................ bad news
            the power cable runs inside of one of the coolant hoses.... without water..........PPPpppFFFFfffttt finito...
            Hope you have a spare 17 series air cooled torch
            H80N
            Senior Member
              Thanks for that info. This torch has recently started popping a couple of times and that surprised me as to what could cause it to pop. The metal is always super clean.
              Yes I once had a 17 torch but it went with my Miller Syncro180 machine when I sold it.
              I will start searching for another torch I guess.
              Coolmate 3
              Victor O/A Rig
                I bet that's a pretty cool sound....PPPpppFFFFffftttfinito....
                  kinda like the sound that one inch of green cannon fuse makes when you light it off....
                    Good place to look
                    http://www.ebay.com/dsc/TIG-Torches/...t=67062&_odkw=
                      Buy two while you're at it. That way next time you don't have to stop the show. I hate not having a part like that.
                        Any luck on a new torch yet....??...
                          Make you replace it with CK 20 or you'll have to change the power hose
                          Miller 30-A Spoolgun
                          Miller WC-115-A
                          Miller Spectrum 300
