Miller bluestar 2e ac dc parts
  • #31
    I like mine a lot runs better after the valve adjustment ,the blue stars are good machines I've used newer bobcats and hobart champions at work and seems like the arc is smoother on the bluestar .I also like the fact that it puts out ac current at 1800 rpm good for power at the house when it's out .The only issue I had was the ignition coil witch they don't make anymore so I made my own ignition .I even bought a spare engine just for parts just in case ,keep the oil level in check and a good air filter is key.I like the old cast iron engines there durable newer kohlers not so Mutch already rebuilt a few with low hrs broken valves etc .all the parts u changed were wear and tare items .Good luck with yours .D
