Spoolmatic 100 and mystery part...?
  • Spoolmatic 100 and mystery part...?
    So, I have a new Spoolmate 100 that I've never used that goes with my Multimatic 200, probably had it about 3 years still in the blow molded case. Never needed it as I also have a 350P and 25' push-pull python gun and use 12" spools. Anyway over the long weekend my youngest son, 10, who has been learning to weld this past year or two and wanted to practice more stick welding. He asked me about the spool gun and I had 1 small spool of 5356 laying around. Since they never have been used together before I had to do the initial 100ipm & 300ipm 24" calibration.
    Problem. On the 100 speed my initial length was only 14" and the 300 speed i only got 18"?? The Multimatic 200 only gives you 4" + or - of adjustment. Usually the initial test is pretty close anyway only needing 1/4 or 1/2" of adjustment. I know it's recommend only to run 4043. I rarely if ever use that and figured eh, we'll see if I can get it to weld with 5356. I have to pickup a few spools of 4043 tomorrow and run the calibration again, it will be interesting to see the difference.
    My question is I have a mystery part in the case and for the life of me can't figure out what it's for. I can't find it in any manuals and it doesn't have any obvious part number. I know it doesn't go to the Multimatic 200, I'm thinking it may be for some other Spoolmate compatible machine to turn off the internal wire drive motor when using the spool gun? The only other thing I can think of is I have a pigtail to adapt normal 14pin to 6 pin when TIG welding to hookup a remote. I just keep it in the blow mold case with the spool gun. Maybe it came with that originally, but I don't remember. Any ideas?
    Ryan
    DYNASTY 350 w/Wireless pedal
    COOLMATE 3.5
    CK WF1
    SPECTRUM 375 X-Treme
    (2) DIGITAL ELITE helmets
    Weld-Mask goggles/hood
    OPTREL e684 helmet
    SMITH torches
    HARRIS torches
    Looks like the Spoolgun adaptor kit.........
    letting you switch between whip and spoolgun
    However........................
    the literature I have found says that gun is direct connect...to the MultiMatic 200... no kit needed..........
    SO............. still a mystery.............
      I remember those parts coming with mine. They are still in the back of a drawer in my toolbox because I didn't need them for my MM211. There was an instruction sheet packed with them-I think there is one particular welder that needs those parts added to run the SPM 100, but I can't remember which one. Will check tomorrow and see if I saved the paper. I think remember the paper said most people would not need them
        Maybe for the Syncrowave 210...??? that needs a kit.....
          Found the parts, still sealed in their bag. Needed for MM140 and 180 only.
            It is for machines that are not direct connect.
            You needed to install this to switch between the regular gun and Spoolgun.
            Ed Conley
            MM252
            MM211
            Passport Plus w/Spool Gun
            TA185
            Miller 125c Plasma 120v
            O/A set
            SO 2020 Bender
            You can call me Bacchus
              Mystery solved........................
              Thank You.....
                I had no good reason to save those but now I guess it was worth it. :-). Back in the drawer for who knows what future use.
                  Thanks. I knew there HAD to be some reason it was in that case.
                  Yep, I just found it on a page in the Spoolmate 100 manual I downloaded from Miller. Go figure, it would be in the manual...I thought I had looked there but must have been reading the Multimatic manual at the time. I guess I'll keep the part it and LABEL it now in case I ever want to sell.
                  Ryan
                  COOLMATE 3.5
                  CK WF1
                  OPTREL e684 helmet
                  SMITH torches
                  HARRIS torches
                    You did better than I did. I looked in the manual first and couldn't find it last night, so found the part this morning. I still need to make the "Bob mod" to mine so it can take standard contact tips. The factory ones are expensive, and really easy to destroy.
                      Yeah, I have to do the mod as well
                      Ryan
                      COOLMATE 3.5
                      CK WF1
                      OPTREL e684 helmet
                      SMITH torches
                      HARRIS torches
