does any one have the wiring schematic for both and where to buy the plug to put on the gun to plug into the lincoln welder any help would be greatly appreciated
30a to lincoln 256
I think Cruzier out in Edmonton builds a magic box for that connection. I thought the voltage out from the 256 was not the same as the 30a uses. And everyone loves the 15/30a for a spool gun.
---MeltedmetalLast edited by Meltedmetal; 03-06-2019, 07:28 AM.---Meltedmetal
Getting the Lincoln spoolgun would make the most sense.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Does the 256 have the 7 pin connector for a spool gun? I made an adapter to connect my 30a to my lincoln. It works fine on normal cv. The pulse programs take some tweaking but I have been able to get decent results even with that. Pretty sure the 256 doesn't have any of the fancy features tho. I'll post part #s and wire diagram laterwww.silvercreekwelding.com
Miller Trailblazer 325 efi
Miller extreme 12vs
Thermal arc 186 ac/dc
Sorry got busy yesterday
for the lincoln end you will need the following parts:
654-MS3106A16S-1PW (note: I had bought 654-MS3106A16S-1P which ended up having the wrong clocking. It still worked I just had to cut a new notch to make it line up with a little dremel tool. This W version should be the correct one)
97-3057-1008
For the miller you will need
MS3101A18-1S
97-3057-1010
I order the parts online usually through mouser or digikey.
Use at your own risk, I don't take any responsibility if the part #s are wrong.
I got the wiring diagrams through the spoolmatic manual and mk cobras manuals.
All I ask in return is that you confirm it all worked when you do it so other can share the information.
Then make the following connections:
Lincoln to Miller
A to C
B to B
C to E
D to F
G to H
E to D
F to G
For reference the lincoln 7 pinout is:
A - motor lead +
B - motor lead -
C - Pot
D - Wiper
C - Pot
E - switch
F - switch
Miler:
A - not used (grounding wire)
B - motor -
C - Motor +
D - switch
E - Pot
F - wiper
G - gun switch
H - gun switch
I - not used
J - not used
Miller extreme 12vs
no problem! Just went through it myself about a month ago and couldn't find the information anywhere so it took a bit or research. It would be nice to have a sticky on the forum with various amphenol part #s and usage.www.silvercreekwelding.com
Miller extreme 12vs
Ya its the female version of whats on the 30a. That way you can just make a short pigtail adapter. You would need some wire to connect the 2 togethor. Probably see if you can get some 16/4 and 16/3 sjow wire from an electrical place since there are 7 wires. Or do the el chepo method like me and just use single wires and rap it all in electrical tape. If you dont want to ever use it again on a miller then ya you just need the lincoln connectors. You'll have to map the letters on the plug to the wire colors. I wanted to be able to use my spool gun on my trailblazer and lincoln welder thats why i went with an adapter. Im suprised no ones doesn't just sell an adapter.www.silvercreekwelding.com
Miller extreme 12vs
