I have a miller 252 I purchased new about 2 years ago and had feed problems when I used it last night for the first time in about 6months.
Problem - inconsistent feed rate. What appears to be happening is the wire is "binding" on the spool and causing the drive rollers to slip while it's peeling it off the spool ( you can hear the tension is super tight because it sounds like a guitar string as the wire tries to hop sideways off the spool). While watching the spool turn it looks like it has a wobble, makes it 2/3 of the way around fine and welds great then it binds for about 1/3 of the spool rotation when the spool kicks off center, if you weld through this it tries to burn back and wire will get a glob on the end but doesn't fry the contact tip and will continue to weld normal again for about 2/3 of a spool turn.
Ive tried changing to a new spool, adjusting drive rollers up and down, jogged off about 20' of wire... After reading a bit last night it sounded like it could be the tension on the spool spindle (lack of a better name).
Any input or suggestions would be appreciated.
Thanks - Brandon
Thanks - Brandon
