So few months ago i started using my mig setup since i had run out of gas for my tig setup and needed to continue working on my project. So i had small spools of wire and set it up, after a number completions wire was no longer feeding, so i opened to check and found that the spool had come unraveled. Since these spools were not the full size that the machine is setup to use, is there a trick to use these smaller spools so i can finish up the spools?
Or is there a adapter that i need in order to use the smaller spools?
