Late 70s era TB AC/DC. When I removed the cover, I could see someone had pulled out one of the fan motor wires, and, instead of a dirty plastic fan atop the fan motor, there was only a tiny elliptical remnant of plastic. Someone has broken off the blades, and removed all the debris from inside the cabinet. Expecting the lack of fan cooling to cause an increase in heat somewhere, I carefully examined the transformer coils, and after some sweat and effort, I was able to locate an area of heat build up. The lower transformer had previously been soldered/brazed by a blind man, and the soldered connection to the coil underneath the glass tape had broken.
Oddly, nothing else inside the cabinet appears to have been tampered with. This guy just hated fan noise I guess, or, wanted to send a message to the future.
I have two questions:
1) IF there is enough of a stub of square coil wire under the tape, would a mechanical connection be better than a soldered/brazed connection? I can make a square hole in a copper round, with compression screws that could couple the two ends.
2) I have not yet tested the four tube diodes. It does not appear flames have shot from them. So, I wonder what the experts here predict: Are the diodes necessarily fried from the 'non-fan', or, even though the heat fried the coil, did the diodes escape injury?
Regards,
Sunnyside
Regards,
Sunnyside
