Welded on a new machine today and th e amperage knob had 1 through ten on it. How do I know exactly what amperage em I at. I kept it at 4 that burned pretty well.but I will still like to know what the numbers actually mean.
Amperage 1-10
Originally posted by Krod1218 View PostWelded on a new machine today and th e amperage knob had 1 through ten on it. How do I know exactly what amperage em I at. I kept it at 4 that burned pretty well.but I will still like to know what the numbers actually mean.
Many times 1-10 is 10-100 percent output.
What make & model....???
Originally posted by Krod1218 View PostSo what would that be? 40% off 250 =100
it depends on the machine you are using.
That would be correct IF the range is 0-250....
WillieDynasty 280DX
Bobcat 250
MM252
Spool gun
Twentieth Century 295
Twentieth Century 295 AC
Marquette spot welder
Smith torches
I dug out my manual. Set the range. Setting the right knob is 10-100% of the range you've chosen. The middle range for stick work is 80 amps wide. 8 being 80%, 80% of 80 amps is 64 amps. Add 64 to the low end of the range of 60. Amperage would be 124, a good heat for a 1/8" 7018 electrode. Mine stays close to there most of the time.
WillieDynasty 280DX
Bobcat 250
MM252
Spool gun
Smith torches
if on the mid range, you were 60+30. The low end of the range and .375 times the 80 amps in the range. Still a cold weld.
WillieDynasty 280DX
Bobcat 250
MM252
Spool gun
Smith torches
